how to shortin a 78-79 bronco dana 44
first get the front axle striped and set it on a pair of jack stands ,take a few
measurements from both sides, so that you have something to compare to.
after you cut the end off you will need the measurements to align it back up .
take as many as you think you need its very inportant so it comes out straight
again
again
- Attachments
- MVC-276F-100x75.jpg (2.46 KiB) Viewed 9718 times
- look close yopu can see the crack
in the weld this will need to go all
the way around before it will come
off.
i used a big log splitter to knock the cast
wedge off .worked like a charm - MVC-275F-100x75.jpg (2.29 KiB) Viewed 9718 times
- turn your grinder so that you can
grind a little into the cast wedge so
that you crack the weld - MVC-274F-100x75.jpg (2.91 KiB) Viewed 9718 times
- Grind untill you get
this look - MVC-272F-100x75.jpg (2.79 KiB) Viewed 9718 times
- then grind the weld off from
around the outer edge - MVC-273F-100x75.jpg (2.85 KiB) Viewed 9718 times
- Attachments
- now this is the important part remember were i said to
measure things ,now get those mesurements out and set
it back up like it was before you choped ot down ,then
weld it ( if you trust your welds go for it) i had a friend
weld mine back up he h - MVC-281F-100x75.jpg (3.11 KiB) Viewed 9706 times
- then i used the same splitter to tap
tap tap it back on . - MVC-278F-100x75.jpg (3 KiB) Viewed 9706 times
- i used a big log splitter to knock the cast
wedge off .worked like a charm - MVC-277F-100x75.jpg (2.97 KiB) Viewed 9706 times
where all did you measure from?
I was thinking to mark several lines around the tube then reset it up so all the marks line back up.
I have been thinking of doing this for my EB to get a HP front...thanks
mccutcheon4
you can do it either way, but it is just the most common. most ford D44's are coil sprung and the BII is coil sprung so it just makes sence. the factory ford 3 link is an easy system to set up and proven off road.
mccutcheon4
mccutcheon4
Thanks !
I will cut the long side, respline the axle, and relocate the
radius rod mounts using the 1/2 ton mounts. I think I can figure out the
spring pocket and shock locations. (the steering linkage may be another story)
I'm wondering about caster now. The only way I can see to dial in positive caster would be lowering the back of the radius rod. I want street use, be an option.
I'm getting way ahead of myself here, but researching and planning a project is a big part of the fun.
This is a really good forum for B2 information, thanks again to all you guys
For steering use the Chevy 1 ton TRE's and threaded dom tube, it's the slick setup but you have to ream the knuckles and pitman arm (not hard).mccutcheon4 wrote:
For the caster you want to cut the other inner c wedge off and set the pinion angle then weld the c's on where ever you want the caster.
HTH
