what side do you wrist...radius arm
NMB2
Post by NMB2 »
what side...driver isnt it? trac bar stops articulation before d-shaft will. :confused:
wilber
Post by wilber »
pass side look on the main page nobody did a write up i belive
NMB2
Post by NMB2 »
ive been looking on the writeup...he doesnt say which side
broncoo
Post by broncoo »
passenger side or whatever side is your long side ask rockcrawler what
happened
pretty sure it messes with the pinion angle pretty good if you put it on the diff side
yeah.... you want it on the passenger side, or the side opposite the diff.
Yeah if you put it on the driver side it will drop the pinion when the pumpkin drops so it binds the u joints with a little drop. But when its on the other side it kicks it up so your front u joint really never changes its angle.
