760X?
Posted: Sat May 21, 2005 1:21 pm
I was looking to get some spare parts for the shake down run and was looking at the 760x axle joints......the axle I am running now has the 297x and I was wondering if anyone knew if I needed to alter the axle itself to hold make it hold the 760x?
also a D44 lockout is a D44 lock out right? if I get some off a TTB will it work on a 79 D44?
Posted: Sat May 21, 2005 8:44 pm
by Phillippi
I was told that TTB and SAS were same lockouts. I hope so as I took the lockouts off the d44 ttb before I sold it.
Posted: Sun May 22, 2005 6:32 am
thats what I was told also. did they look the same when you pulled the axle?
I read MR. N's site again and I think the 760x is a direct replacement so I guess I will grab a couple to take with me.
Posted: Mon May 23, 2005 8:27 pm
ok now I have another question.....are the outers on an IFS D44 the same as the outers on a SA D44?
does anyone have a link to a full axle length chart?
I might have access to a TTB D44 for some swapped parts and was just wondering what all I can use.....
Posted: Mon May 23, 2005 8:28 pm
I believe the 297x is a discontinued item, replaced by the 760x
The lockouts are interchangeable, even among cheby.
Posted: Mon May 23, 2005 8:29 pm
DBrown wrote:ok now I have another question.....are the outers on an IFS D44 the same as the outers on a SA D44?
Only the bearing hub and rotor are the same. Everything else is different.
Posted: Mon May 23, 2005 8:39 pm
that is kinda what I figuered I just wanted to make sure.....MR.N's site kinda talks about the 760x but it is not realy spelled out.
do we have an axle chart on here?
I have a link on some 77 1/2 ton cheby axles also.
Posted: Mon May 23, 2005 9:45 pm
