My second questions is how do i tell if its 4x4 or not? please let me know how to tell!
1988 Bronco 2....2 questions to ask..sputtering
- Mud Addict
Re: 1988 Bronco 2....2 questions to ask..sputtering
Does it have 2 drivelines?
Haha thanks.__. But how do I tell. Cause idk of there's a switch or what to activate the 4x4. Im more of a tech nerd than a car nerd ;p
Has any smoke leaked out of the wires yet?
Nope not yet. :(
Well I found out what was wrong. While we were changing the alternator, a spark plug wire came undone and was very loose. Just tightened it up and now works like a charm(: thanks for the help. Next question is how to tell if I have 4x4 or not :/
- Mud Addict
Seriously does it have two drivelines? One to the rear axle and one to the front axle? Does it have front hubs or just center caps on the front rims?
Mudhog1977
How many gear shifters does it have? Does it have any buttons mounted to the headliner above the rearview mirror? If u look under the front of the truck does it have a circle of bolts about a foot from the driver side tire? Does it have 1 or 2 driveshafts?
No bottons over the mirror
- Mud Addict
Would not be above the mirror, would be in the middle of the dash right above the stereo. And my '88 is a manual shift t-case, so if you have a 5-speed trans there will be be stick coming up out of floor.
Nothing in the middle just my radio and air control stuff. Mine is automatic. The only thing that is in the middle is the thing that tells me when my gas is low and when I press the brake.
Mudhog1977
Then its probably 2wd
Awe well that sucks. I wanted a 4x4
