towing a 1988 Bronco ll
Posted: Fri Jul 15, 2011 7:38 pm
by skag101
I have a 1988 Bronco ll . Is it possible to flat tow this behind a motorhome or would it have to be on a tow dolly with the driveshaft removed?
Re: towing a 1988 Bronco ll
Posted: Fri Jul 15, 2011 8:23 pm
by didittwice
From what I am seeing no you have to pull the drive line out and use a dolly?????????
Posted: Fri Jul 15, 2011 8:34 pm
All ya gotta do is put the T case in neutral and the trans also. That is if you have a standard T case.
Posted: Sun Jul 17, 2011 10:56 am
by drofman
I put the t-case in neutral and the tranny (manual) in 1st so the mainshaft won't spin and wipe out the pocket bearing on the input shaft.
Posted: Sun Jul 17, 2011 10:59 am
by drofman
And leave the steering wheel unlocked, I know, you have to put the key on the 1st click. make sure it not on run
