towing a 1988 Bronco ll
skag101
Post by skag101 »
I have a 1988 Bronco ll . Is it possible to flat tow this behind a motorhome or would it have to be on a tow dolly with the driveshaft removed?
didittwice
Re: towing a 1988 Bronco ll
Post by didittwice »
From what I am seeing no you have to pull the drive line out and use a dolly?????????
Post by tekatlarge »
All ya gotta do is put the T case in neutral and the trans also. That is if you have a standard T case.
drofman
Post by drofman »
I put the t-case in neutral and the tranny (manual) in 1st so the mainshaft won't spin and wipe out the pocket bearing on the input shaft.
snow in sandiego.jpg (5.89 KiB) Viewed 2899 times
drofman
Post by drofman »
And leave the steering wheel unlocked, I know, you have to put the key on the 1st click. make sure it not on run
