towing a 1988 Bronco ll
I have a 1988 Bronco ll . Is it possible to flat tow this behind a motorhome or would it have to be on a tow dolly with the driveshaft removed?
didittwice
Re: towing a 1988 Bronco ll
From what I am seeing no you have to pull the drive line out and use a dolly?????????
All ya gotta do is put the T case in neutral and the trans also. That is if you have a standard T case.
I put the t-case in neutral and the tranny (manual) in 1st so the mainshaft won't spin and wipe out the pocket bearing on the input shaft.
- Attachments
- snow in sandiego.jpg (5.89 KiB) Viewed 2903 times
And leave the steering wheel unlocked, I know, you have to put the key on the 1st click. make sure it not on run
