Page 1 of 2
				My bronco ll switch
				Posted: Wed May 25, 2011 7:43 am
				by didittwice
				Ok started my bronco ll switch not what I really wanted but it will work change over from auto to manual .
I know it is not very exciting but its what I have right now.
				Re: My bronco ll switch
				Posted: Wed May 25, 2011 6:46 pm
				Pictures, pictures, pictures, pictures
				Posted: Thu May 26, 2011 3:05 pm
				by didittwice
				Posted: Thu May 26, 2011 3:06 pm
				by didittwice
				Posted: Thu May 26, 2011 3:20 pm
				by didittwice
				Well that did not work out blasted comp. OK the blue one is the 89 it had the a4ld the brown one has 89 motor and fm146 tranny witch I put in now I am taking them out as one so I do not have to go buy another slave cyclinder.
so the motor and tran. is out of brown one and starting to remove out of blue one.
				Posted: Fri Jun 10, 2011 6:12 pm
				by didittwice
				It is out now to clean add parts that will be needed and if I could figure out this pic thing I will post.
				Posted: Fri Jun 10, 2011 6:36 pm
				by didittwice
ok now I figure it out blast
				Posted: Fri Jun 10, 2011 6:47 pm
				by didittwice
				Posted: Fri Jun 10, 2011 6:52 pm
				by didittwice
				this is going in
				Posted: Fri Jun 10, 2011 10:09 pm
				Ya got half the battle done. What are you going to have to do about power brakes and room for the clutch master Cylinder? I didn't see how the brown one was setup?
				Posted: Sat Jun 11, 2011 7:15 pm
				by didittwice
Ok i hope it fits just like this right behind the power brake I just got the blue one cleaned so I can check it out if I have to I will used the one out of the brown one.
				Posted: Sat Jun 11, 2011 7:23 pm
				by didittwice
				Posted: Fri Jun 17, 2011 8:45 pm
				by didittwice
 ok clutch master cylinder,Brake and clutch pedals in and power brakes back in.
				Posted: Fri Jul 15, 2011 8:04 pm
				by didittwice
				OK I am back ok A little paint
  and some sand blasting to clean the air intake up
 and then put the exhaust back and the  motor
				Posted: Wed Jul 20, 2011 9:10 pm
				by didittwice
				OK it is in now all I have to do is remember where everything goes???
