My bronco ll switch
My bronco ll switch
Ok started my bronco ll switch not what I really wanted but it will work change over from auto to manual .
I know it is not very exciting but its what I have right now.
Re: My bronco ll switch
Pictures, pictures, pictures, pictures
Well that did not work out blasted comp. OK the blue one is the 89 it had the a4ld the brown one has 89 motor and fm146 tranny witch I put in now I am taking them out as one so I do not have to go buy another slave cyclinder.
so the motor and tran. is out of brown one and starting to remove out of blue one.
It is out now to clean add parts that will be needed and if I could figure out this pic thing I will post.
this is going in
Ya got half the battle done. What are you going to have to do about power brakes and room for the clutch master Cylinder? I didn't see how the brown one was setup?
OK I am back ok A little paint
and some sand blasting to clean the air intake up
and then put the exhaust back and the motor
OK it is in now all I have to do is remember where everything goes???
