87 bronco won't go in to 4wd
keithbythebay
Post by keithbythebay »
I have a 1987 ford bronco II it as automatic 4wd that won't engage the switch lights up but nothing happins need some advise.
satyner
Re: 87 bronco won't go in to 4wd
Post by satyner »
More than likely your 4wd switch motor. It usually takes a beating being mounted in a wide open place underneath the chasis. Its easy to replace.
keithbythebay
Thank you Satyner all give that a try.
