rear axle seals
Posted: Wed Jun 30, 2010 8:50 pm
by Hunter66
everything is off around the axle but the axle wont budge. any suggestions of how I might get the axle out w/o doing damage;. I have Detroit lockers in the rear if that helps. she is a 70' bronco,
Re: rear axle seals
Posted: Fri Jul 02, 2010 3:02 am
by Ranger Dave
Re: rear axle seals
Posted: Sat Jul 03, 2010 4:23 pm
by clem
A '70 bronco has a 9" rear end, no c-clips.( dave you know that
) Use a slide hammer after you remove the four bolts behide the drum. I used a piece of threaded rod (allthread?) with a large washer and nut through the hole on the axle, and a picce of smal pipe with two railroad spikes welded on it. see crude picture. I hope this helps, Oh you'll need ice for your hand after, I suggust cold beer.
Re: rear axle seals
Posted: Sat Jul 03, 2010 4:26 pm
by Ranger Dave
sorry, my bad
Re: rear axle seals
Posted: Sat Jul 03, 2010 9:30 pm
by drofman
I have just wrapped a chain around the axle and used it like a slide hammer
