rear axle seals
rear axle seals
everything is off around the axle but the axle wont budge. any suggestions of how I might get the axle out w/o doing damage;. I have Detroit lockers in the rear if that helps. she is a 70' bronco,
Re: rear axle seals
A '70 bronco has a 9" rear end, no c-clips.( dave you know that
) Use a slide hammer after you remove the four bolts behide the drum. I used a piece of threaded rod (allthread?) with a large washer and nut through the hole on the axle, and a picce of smal pipe with two railroad spikes welded on it. see crude picture. I hope this helps, Oh you'll need ice for your hand after, I suggust cold beer.
- Attachments
- slide hammer 2.JPG (16 KiB) Viewed 3502 times
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
'56 international s110
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
Re: rear axle seals
I have just wrapped a chain around the axle and used it like a slide hammer
