Driveline angles
Posted: Fri Oct 08, 2004 4:56 pm
by b2binbad
Need some help. Hit a few piles today to check flex. I've still got the "revolver shackles" installed. They're coming off, they suck! My question is, when I got home, I noticed the u-joint retainer bolts on the rear end were bent from rubbing on the slip yoke. I set my caster angle at 17 degrees with about 4-5 inches of lift. If I remove the shackles, am I cured?? Here's a pic of my set up. Double cardon @ t-case.
Posted: Fri Oct 08, 2004 5:29 pm
by FatMan
i remember reading in one of my 4wheel mags that you want to have a both end's at a angle. the top look's good but the bottom should probabaly be at a lower angle (tilted downward).
Posted: Fri Oct 08, 2004 5:50 pm
by wilber
http://www.pirate4x4.com/tech/billavist ... index.html
read up, thats where i go for my drive line questions...
Posted: Fri Oct 08, 2004 6:46 pm
by FatMan
good info wilber
Posted: Fri Oct 08, 2004 7:34 pm
by b2binbad
Cool, thanks Wilber, My setup looks right. Bye- Bye POS shackles!
--Les
Posted: Sun Oct 10, 2004 6:03 am
by Ranger Dave
what are you guys using for a t-case end front driveshaft u-joint?? I have a 4/5in lift with a dana44.The axel end is ok but the t-case end
heres what ive done so far
http://www.fordmuscle.com/phpBB/viewtop ... orum=19&18[/img]
Posted: Sun Oct 10, 2004 5:54 pm
by b2binbad
I'm using the same thing you pictured. Don't know how it's gonna work though as I'm still building up the front. I do know that the full size Ford trucks has the same t-case end and came in different lengths.
HELP WITH REAR DRIVESHAFT ISSUES
Posted: Wed Jan 12, 2005 9:51 pm
by jerrysbroncoii
I HAVE AN 88' BRONCO II THAT I AM GOING TO PUT A 6" SKYJACKER SUSP. LIFT ON, BUT I HAVE THE DRIVE SHAFT THAT LOOKS LIKE A CV JOINT WHERE IT GOES INTO THE DIFF., AND I KNOW IT NEEDS TO BE CHANGED BUT I DONT KNOW WHAT TO,
Posted: Mon Jan 17, 2005 3:53 pm
by b2binbad
I had to have a rear driveshaft made. Cost me 80 bucks. I just reused the stuff I had and they provided a longer tube. I got the fronts(have like 5 --different lengths) from the junkyard. I pulled them from different vehicles.
