Worth the trouble?
Worth the trouble?
Found a 1984 bronco 2 with a drivers side busted knuckel for 400. I havent seen it in person but everything works ok from what he says. Is it worth fixin for the 400 bucks?
Re: Worth the trouble?
go look at it first.how did the knuckle get broke?? musta hit sumpin awfull hard
the knuckle doesnt break while driving down the road. the owner must have beat that thing and finanly hit something when he was four wheeling. i wouldnt do it he probably beat it up. you can find better ones for the money.
I know people here like them bottom t-stat motors but I like not having to adjust valves and messing with the carb. and if you just overheat it a little the heads pop. I know 2.9 heads don't like the heat also but atleast I can find them.
