Worth the trouble?
yardboss
Worth the trouble?
Post by yardboss »
Found a 1984 bronco 2 with a drivers side busted knuckel for 400. I havent seen it in person but everything works ok from what he says. Is it worth fixin for the 400 bucks?
Re: Worth the trouble?
go look at it first.how did the knuckle get broke?? musta hit sumpin awfull hard
forman621
Post by forman621 »
the knuckle doesnt break while driving down the road. the owner must have beat that thing and finanly hit something when he was four wheeling. i wouldnt do it he probably beat it up. you can find better ones for the money.
drofman
Post by drofman »
I know people here like them bottom t-stat motors but I like not having to adjust valves and messing with the carb. and if you just overheat it a little the heads pop. I know 2.9 heads don't like the heat also but atleast I can find them.
