rear end swap
BroncoOn33s
rear end swap
if i swap to explore 8.8 with 4.10 grears what can i get that has 4.10 in it for the front stock
greenmachine89
Re: rear end swap
You could check local yards for front ends but you would have to do a lot of calling. You also could go to car-part.com they have a national database of all the wrecking yards and you could find a frontend there. If 4:10's came stock in the rear then there has to be one for the front.
If you do put that rearend in you will have to change the spring mounts to the top of the axle and you will have to make your own shock mounts. You should check into the bolt pattern of your drive line. Mine was like 4 inches from bolt hole to bolt hole on the b2 drive line and the explorer drive line had like 4 1/2 inches so I had a new drive line made. 400 bucks! So check that before you start. A ranger rearend will bolt right no changes at all.
BroncoOn33s
Re: rear end swap
what gearin norm comes in the front of the explor front axles. i no every thing about the exploer 8.8 i have put a few of them in
greenmachine89
Re: rear end swap
My 91 ex has 3:73's for the front and the rear end i got for my b2 had 3:73 in the front also. I think they also came with 3:23's? As for 4:10's if that was stock I belive those gears came in the sport models.
BroncoOn33s
Re: rear end swap
what about front and rear axles out of a 78 bronco. will they work with a little more fab work
Re: rear end swap
Anything will work with the corrct knowhow and the right tools. I think the main problem with the Full size bronco axels are going to be just that, they are full width and the suspension components will not line up you would have to do some serious fabrication on the frame to accomodate the front axle. I'm not sure but the EB axles should be the correct width to just fit in.
'89 Bronco II
'03 GMC Sierra Z71
'89 Bronco II
'03 GMC Sierra Z71
