								nickb
		Posts:  10  		Joined:  Sun Oct 22, 2006 5:13 pm
						Post
								by nickb   »  Mon Jul 23, 2007 9:45 am
			What size socket or wrench do I need to take the bolts out of the square flange on each end of  the rear driveshaft and how hard are they to get out. THANKS FOR ANY HELP   NICK
								BDEUCE
		Posts:  135  		Joined:  Wed Jan 03, 2007 8:24 pm
						Post
								by BDEUCE   »  Mon Jul 23, 2007 10:24 am
			i believe they are a 13 mm 12 point ...maybe a 12mm 12 point. i know i had to borrow a socket for it
if you have the right tool, it's not hard. i changed my entire driveshaft in 10 minutes.
		Posts:  1193  		Joined:  Mon Apr 19, 2004 9:11 pm
						Post
								by Phillippi   »  Mon Jul 23, 2007 10:58 am
			They are 12mm 12 point.  Easy to take off.
								steiner_5000
		Posts:  66  		Joined:  Mon Dec 04, 2006 12:49 pm
						Post
								by steiner_5000   »  Wed Jul 25, 2007 7:49 am
			just make sure you have your tires blocked so it dont roll away
		Posts:  2233  		Joined:  Sun Apr 18, 2004 6:38 pm
						Post
								by Nobody   »  Wed Jul 25, 2007 9:08 am
			I've also found that flange is usually stuck, so you may need a pry bar to pop it loose. You want to avoid hitting the yolk ears with a hammer.
