				Stuttering when driving down the road
				Posted: Thu May 31, 2007 10:46 pm
				by greenmachine89
				I have a 89 B2, 2.9, no lift, 5 speed, and an anoying problem. When I get going anywhere it starts an anoying stutter. 25, 35, 55 mph it doesn't seem to matter. It does a stutter that I have never encountered. I replaced the cap, rotor, wires, and spark plug. I have ran seafoam though the fuel lines. It doesn't get worse fast or slow it stays the same. It seemed to go away after I changed the spark plug wires but now is back just like before. I does go away under accleration but returns when I reach the speed limit. This sucks!
				aweful stutter
				Posted: Thu May 31, 2007 11:35 pm
				by Paul
				have you ever changed the fuel filter? and check the timing, also look for vacuum leaks, as any of those might cause the problem, and also exhaust leaks can create the problem also
				Posted: Thu May 31, 2007 11:38 pm
				by Paul
				i have heard the ecm can make one do that but anytime i have ever had a problem with a ecm it just died as soon as the car would warm up and not run after untill it cooled again.
				Posted: Fri Jun 01, 2007 7:23 am
				by greenmachine89
				I have changed the fuel filter just a few days ago as a matter of fact. As for timing I have not done that. As for ECM it could be time for a new one.
				Posted: Fri Jun 08, 2007 2:04 am
				by Paul
				well when you get that done get back with us, hopefully by then it will be running right again ........
				Posted: Fri Jun 08, 2007 12:34 pm
				by greenmachine89
				Hate to say it but I found two small hoses that had leaks causing the stutter. I couldn't see them because they were covered and did not make the noise that most leaks make. All better!
				Posted: Fri Jun 08, 2007 8:14 pm
				by Paul
				at least you found it..... nothing wrong with that
				leaks
				Posted: Sat Jun 16, 2007 4:03 pm
				by bower100
				greenmachine,
  tell s where the two small hoses were that had leaks.  Like to check mine as well.
 dave
