Stuttering when driving down the road
				greenmachine89
I have a 89 B2, 2.9, no lift, 5 speed, and an anoying problem. When I get going anywhere it starts an anoying stutter. 25, 35, 55 mph it doesn't seem to matter. It does a stutter that I have never encountered. I replaced the cap, rotor, wires, and spark plug. I have ran seafoam though the fuel lines. It doesn't get worse fast or slow it stays the same. It seemed to go away after I changed the spark plug wires but now is back just like before. I does go away under accleration but returns when I reach the speed limit. This sucks!
aweful stutter
have you ever changed the fuel filter? and check the timing, also look for vacuum leaks, as any of those might cause the problem, and also exhaust leaks can create the problem also
				greenmachine89
				greenmachine89
Hate to say it but I found two small hoses that had leaks causing the stutter. I couldn't see them because they were covered and did not make the noise that most leaks make. All better!
