				vin #
				Posted: Sun Apr 29, 2007 7:28 pm
				by Mothers Mistake
				looking to decode a 1989 and a1988 bronco II one 6 cyl 2.9 auto and one 2.9ltr. 5speed both 4x4  ..where can i find info on www
                                             Thanks Terry
				Posted: Mon Apr 30, 2007 8:41 pm
				by bower100
				In the front of a Clymers ford BroncoII/Ranger service manual.
 I have one... not in front of me ATM, but I know 6th/7th digits designate whether it's a  4x2, 4x4, reg cab, super cab or bronco.
  What did you need to know?
 dave
				Posted: Tue May 01, 2007 5:04 pm
				by Mothers Mistake
				with out crawling under it in the mud.. whant to know what axles they have.  #s i found are 1989   axle =D4  and 1988 axle =44. is this just front or front and rear, they are both 4x4  Thanks Terry
				Posted: Tue May 01, 2007 5:50 pm
				by BDEUCE
				CODE:           DEFINITION:
42                    3.45
44                    3.73
47                    4.10
D2                   3.45 (limited slip)
D4                   3.73 (limited slip)
D7                   4.10 (limited slip)
On 4x4’s, there is a Dana 28 axle up front, until october 1989 (check your build date, you may have a 35) when it was replaced with a special Dana 35. The front axle should have the same gear ratio as the rear. The D35 is a stronger (than the D28) and can be swapped over from a Ranger, or exploder, (or newer BII, if not already equipped). The D28 can be re-geared; however, units with the 3.45 ratio, going to a lower (numerically higher) ring and pinion gear must use the appropriate housing. to tell a 35 from a 28, the bolts on the diff - a 35 has ten, and a 28 has 12.
All Bronco II’s came with a special version of the 7.5” rear, which has a capacity of 2640lbs. Other Ford 7.5” axle housings will NOT work in place of the BII unit; however, the rings and pinions from any 7.5 can be swapped into it.
I have a d4 code, trac loc in back, and open dana 35 diff in the front, 3.73 from factory.
hope this helps
nate
				Posted: Tue May 01, 2007 7:14 pm
				by Mothers Mistake
				perfect  thankyou....
				Posted: Thu May 03, 2007 12:48 pm
				by Cruff
