looking to decode a 1989 and a1988 bronco II one 6 cyl 2.9 auto and one 2.9ltr. 5speed both 4x4 ..where can i find info on www
Thanks Terry
vin #
Mothers Mistake
CODE: DEFINITION:
42 3.45
44 3.73
47 4.10
D2 3.45 (limited slip)
D4 3.73 (limited slip)
D7 4.10 (limited slip)
On 4x4’s, there is a Dana 28 axle up front, until october 1989 (check your build date, you may have a 35) when it was replaced with a special Dana 35. The front axle should have the same gear ratio as the rear. The D35 is a stronger (than the D28) and can be swapped over from a Ranger, or exploder, (or newer BII, if not already equipped). The D28 can be re-geared; however, units with the 3.45 ratio, going to a lower (numerically higher) ring and pinion gear must use the appropriate housing. to tell a 35 from a 28, the bolts on the diff - a 35 has ten, and a 28 has 12.
All Bronco II’s came with a special version of the 7.5” rear, which has a capacity of 2640lbs. Other Ford 7.5” axle housings will NOT work in place of the BII unit; however, the rings and pinions from any 7.5 can be swapped into it.
I have a d4 code, trac loc in back, and open dana 35 diff in the front, 3.73 from factory.
hope this helps
nate
42 3.45
44 3.73
47 4.10
hope this helps
nate
