Dash brake light and anti lock brake light error
				deathmetalandrez
when i  drive my truck around for a bit codes get set off and my brake light and anti lock brake light  pop on. I have an engine code reader, i popped it in and it told me MAF and MAP sensor overvolt? i notice that when i initially start my truck cold, if i give it gas the lights brighten and as the rpms drop the lights dim a bit. maybe whatever is causing my lights to brighten is giving my sensors too much voltage? i also notice if its very cold outside the codes arent set off (temps around freezing.) any suggestions?
							I currently own 4 bronco 2's. Three of them are 89' of which two are 4x4 and love em. The other is an 85' 4x4 5-spd
				cddavis9343
