15 x 8 rims on a stock BII?
Posted: Fri Jan 26, 2007 9:32 am
I recently picked up a really clean stock BII and budgeted out a J.D. Stage 1 lift to be purchased this month and installed before the beginning of March. Then I had budgeted new 8” rims and 31’s to be put on after I finished the lift. Right before I was going to buy the lift I came across a screaming deal on a set of BF Goodrich 30” Dualers and was talked into buying them. Firestone is convinced I can put these 30” tires on 8” rims without the lift initially. No off-roading but good enough for a daily driver until I get the lift in a couple months. Is this right? Not sure what the offset on the rims is.
Has anyone run their stock rig with 30” x 15 x 8’s without a lift? I’m ok with a little rubbing on tight turns and it’s only for a couple months but is it even doable? Appreciate any input.
