OK how about this
OK how about this
If I put 3'' blocks in the back and 2'' coil spring spacers up front will I have any problems with my drive shafts, transfercase and front alignment on my 87 B2? Could someone give me an answer on this.THANKS FOR ANY HELP
Branman250b
It is stock
Since it is stock would I be able to keep the rear drive shaft if I went with just 2'' blocks in the rear? THANK YOU FOR YOUR REPLY
Branman250b
I don't like blocks. They cause axle wrap and u-joint failure. A much much better solution would be to build new shackle hangers that are lower. It's pretty much free lift.
As for the coil spacers, the TTB front ends have hard enough time keeping the tires pointed striaght. If you add spacers or longer springs without drop brackets, you're just asking for problems.
Branman250b
I figure the best thig to do is just to by a lift kit. If you were wanting to run over 3inches because the way ford designed the suspesion your tire will do this /-\ But 2 inches should be fine.
If it weren't for Chevy, my tools would rust.
If Chevy is the heartbeat of America, then
American needs a pacemaker
texastud1983
Firts off not to get you all stirred up but Branman250b, you got your camble backwards. \--/
I agree with nobody, blocks are crap and if you go with coil spacers in the front getting that thing aligned will be a nightmare. Thats IF they can get the acentric bushings out to adjust the camber. The best thing to do it shop around and find you a lift with new, longer coils and drop brackets.
As for your drive shaft you should get rid of that thing even if you dont lift your BII. I've seen people wheel there stock BII's and have those crapy shafts come apart.
Texas is right. My drive shaft went south when I was headed north (literally)
after a trip trough the center median in Wyoming in a snow storm in route to a Wind Turbine site. NAPA was able to order me a replacement in both lengths and we matched it up in there store front
. It was the single cardigan (one U Joint at each end) but I had no problem after this till the tranny went further south than I was
. I try to keep mine at stock height as I use it for work also and not just play. A man's gotta do what a man's gotta do.
If I can't fix it, It ain't broke.
