				2.8 gasket sets what's the diff 74 - 79 vrs 83-86
				Posted: Mon Jul 24, 2006 1:23 am
				by lookn4dirt
				I can figure the head gaskets intake stuff are the timing covers etc different ?
				Posted: Wed Jul 26, 2006 8:11 pm
				by ranger5.0
				Most of the gasmets are the same. The difference comes in if you use the 84'-85 intake on a 74' and up engine. the water outlets ore different and you will need to use the timing cover off of a 80's model on a 70's model to make it work if you want to run the newer intake. The only other difference in the motors is that the 70's motors were made in Germany.
				Posted: Wed Jul 26, 2006 10:44 pm
				by lookn4dirt
				Thanks, do you know if I can run the mustang block, heads,intake and carb with a later timing cover 80s timing cover ? thanks
