automatic 4x4 switch
kevin.burkman
Post by kevin.burkman »
I am new to this site but was wondering how hard and exspensive it is to change my automatic 4x4 to manual. I have a 88 bronco II the low 4x4 works but the high does not your help would be great.
I don't think there is a way to convert your existing electric shift transfercase to a manual shift. You can easily swap transfercases to a manual shift. Aside from cutting a hole in your floor, it should be a bolt up job.
Check out this write-up for converting from 2wd to 4wd.
http://www.broncoii4x4.com/2wd-4wd/2wd- ... ersion.php
kevin.burkman
Once I swap the t case will I need to new front manual loking hubs also or will the automatic still work. Sorry this is the first bII I have ever owned and not real smart about them :confused:
Your automatic lockouts will work, but they don't have a very good reputation. Most people swap out their auto lockouts for manual.
kevin.burkman
Nobody thanks for the help I appreciate it Kevin
I don't think you have to cut a hole in the floor if you find the tunnel plate for a manual tranfer case rig. It is a bolt in deal. :cool:
kevin.burkman
ranger 5.0 thanks for the help on both of my questions
Fishtank
Post by Fishtank »
i have autolockers and its really nice, but in the end i dont like them, if you are on the trails and in the mud alot they will retain liquids and rust out some. and soon as i get off the trail i go wash my truck so i know its not from letting it sit
86 Bronco II
30'' All Country Radials
