Difficulty Rating
marinebroncoii
Post by marinebroncoii »
it all depends on which 351 it bolts to
Dreded
Post by Dreded »
the 351W should work witha 302 but the 351C won't
4x4'ers Eat More Bush!
kylebronco2
Post by kylebronco2 »
Ok im not positive on the bolt patterns between the 351 C or W, but the c6 i have is from a 351M, and im pretty sure the trans is not in too great of condition, so i would have to go find a new one anyways. Oh well, ill see how it all goes
86 C5 Auto BII, FS Axles, 37 Swampers
marinebroncoii
Then just try to find either another C6 that you know was bolted to a small block or a C4 that will bolt to the NP205 T-case that you have. A C4 will stand up to quite a bit of abuse.
the 351C has a small block bellhousing.......the 351M has a BB bellhousing.
marinebroncoii
Why have I heard so many times that the 351C has a BB bell housing? So the Windsor and Cleveland have a small block bell housing and the 351M and everything bigger had the BB? Is it just that the 351C is a big block with a small block bell housing and people get confused.
