Difficulty Rating
Then just try to find either another C6 that you know was bolted to a small block or a C4 that will bolt to the NP205 T-case that you have. A C4 will stand up to quite a bit of abuse.
the 351C has a small block bellhousing.......the 351M has a BB bellhousing.
Why have I heard so many times that the 351C has a BB bell housing? So the Windsor and Cleveland have a small block bell housing and the 351M and everything bigger had the BB? Is it just that the 351C is a big block with a small block bell housing and people get confused.
