getting ready to roll (not under its own power)
I'll sell you theone tie rod end that needs to be reamed, and give you the part number for the others that you can buy locally. No need to buy those in Ky and ship them across the USA when you can save money by getting them at local parts house. So, we have a tie rod end, reamed(that'll be the left one in the pic) and tie rod tube and drag link tube, tapped and ready to use, shipped to your door for $145.00. You then need buy the other three parts and you'll be set. They should cost about 55.00 for the three. I'll check today and see that all is correct.
92 XJ-wifes toy
92 XJ-wifes toy
Jason, all four of the ends are different, you can mix it up and only run two different ones but it makes aligning very time consuming and difficult. I will have time this week to finish up the one tre I'm reaming for you and do the tubes. Advise if you still have not found a source for the numbers I gave you for as cheap as I can get them here. We will extimate shipping and see if buying and shipping from here would give a savings.
92 XJ-wifes toy
92 XJ-wifes toy
