getting ready to roll (not under its own power)
Bob Myers
Post by Bob Myers »
I'll sell you theone tie rod end that needs to be reamed, and give you the part number for the others that you can buy locally. No need to buy those in Ky and ship them across the USA when you can save money by getting them at local parts house. So, we have a tie rod end, reamed(that'll be the left one in the pic) and tie rod tube and drag link tube, tapped and ready to use, shipped to your door for $145.00. You then need buy the other three parts and you'll be set. They should cost about 55.00 for the three. I'll check today and see that all is correct.
92 XJ-wifes toy
How much for your jam nuts?
Do you know the part number for the tie rod ends? Are all 3 the same? They look different in the pics you guys posted, but that could be due to the amount threaded into the tube.
the reamer is pretty spendy but not to bad. i ordered mine for like $60.00 it did the job good just be carefull when using a power drill you can go to far. i just reamed checked and reamed more if needed. to a little while but got them reamed pretty good.
Bob Myers
Post by Bob Myers »
Jason, all four of the ends are different, you can mix it up and only run two different ones but it makes aligning very time consuming and difficult. I will have time this week to finish up the one tre I'm reaming for you and do the tubes. Advise if you still have not found a source for the numbers I gave you for as cheap as I can get them here. We will extimate shipping and see if buying and shipping from here would give a savings.
92 XJ-wifes toy
Thanks I will let you know if I find anything.
