help
				chris's bronco 2
help
i have a 89 bronco 2 the 4 wheel works fine but... when i put it into 4 wheel about 10 min later it will start to make a screaching nose for the tranfer cases but when i grab the 4wheel drve boot handel it will stop then when i put it back in to 2 wheel drive it will make the same nose as in 4wheel drive for like 5 min then stop so it only when i put it in 4 wheel. anyone that had some problems like these thanks chris
				chris's bronco 2
help
the are manual and wut flueds should i look for and also could it be that i am out of oil in the cranfer case and do u no where the fill hole is thanks.
chris
						chris
				chris's bronco 2
				chris's bronco 2
				chris's bronco 2
				chris's bronco 2
				chris's bronco 2
thatnks man hoprefuly that will doing to trick i only payed $600 for the bronco run and drives grate no rips or diss coloring in the interior nad not on dent or srach a littl squce in the real some places but u can barley hear it thanks.. and is it good to cut your wheel wells out to put biber tiers on it.
also u use the same oil in the front to
gear oil in the front.
You need help with your spelling and grammar first. I couldn't make heads nor tails of the symptoms you are having. Damn, reading your posts was like trying to read the Dead Sea scrolls.......chris's bronco 2 wrote:thatnks man hoprefuly that will doing to trick i only payed $600 for the bronco run and drives grate no rips or diss coloring in the interior nad not on dent or srach a littl squce in the real some places but u can barley hear it thanks.. and is it good to cut your wheel wells out to put biber tiers on it.
