help
chris's bronco 2
help
Post by chris's bronco 2 »
i have a 89 bronco 2 the 4 wheel works fine but... when i put it into 4 wheel about 10 min later it will start to make a screaching nose for the tranfer cases but when i grab the 4wheel drve boot handel it will stop then when i put it back in to 2 wheel drive it will make the same nose as in 4wheel drive for like 5 min then stop so it only when i put it in 4 wheel. anyone that had some problems like these thanks chris
I'm not sure what do say about this one. I guess start by checking fluids, and u-joints.
Auto hubs or manual?
chris's bronco 2
help
the are manual and wut flueds should i look for and also could it be that i am out of oil in the cranfer case and do u no where the fill hole is thanks.
chris
chris's bronco 2
help
There are 2 plugs on the rear of the transfer case. The bottom one is to drain, and the top one is to fill. It should be filled with Dexron AT fluid.
Does is it squeak with the hubs unlocked?
chris's bronco 2
yes it will after about 5 min then after i am done i will free the hubs and it will do it for a short time then stop
chris's bronco 2
sry abput that man did not read it right i dosent make the nose then they are unlocked they will after i am doine 4 wheel and free the hubs back up fpr like 5 min and stop
Is it a non stop screeeeeeeeeeeech.....or a screech screech screech?
Does it change with speed?
chris's bronco 2
it will start then stop then start no stays at one level
check your oil level in the transfer case. Also check the oil level in the front axle.
chris's bronco 2
when filling the tranfer cases and the front axel on the fill hole fill it to it comes of of their. and how do u no if u are low
Well, if you stick your little finger in there and you can't feel anything, then you are low.
Yes, you just fill until it's level with the fill hole.
chris's bronco 2
thatnks man hoprefuly that will doing to trick i only payed $600 for the bronco run and drives grate no rips or diss coloring in the interior nad not on dent or srach a littl squce in the real some places but u can barley hear it thanks.. and is it good to cut your wheel wells out to put biber tiers on it.
also u use the same oil in the front to
gear oil in the front. :cool:
eisle89
Post by eisle89 »
chris's bronco 2 wrote:thatnks man hoprefuly that will doing to trick i only payed $600 for the bronco run and drives grate no rips or diss coloring in the interior nad not on dent or srach a littl squce in the real some places but u can barley hear it thanks.. and is it good to cut your wheel wells out to put biber tiers on it.
You need help with your spelling and grammar first. I couldn't make heads nor tails of the symptoms you are having. Damn, reading your posts was like trying to read the Dead Sea scrolls.......
