steering
steering
I have a fullwidth hp 44 in the front of my b2,  the stock tie rod is bent in a u shape
  and its 100bucks from autozone.  There is no doubt in my mind i will break another.  My question is what steering should i go with? Its trail only rig.  I have 12' of 1.5" dom to use.  Should i go with heims and drill out the knuckels?  Or should i get some one ton tre's.  What do you guys think.
				mccutcheon4
I run the chevy stuff and have been very happy. As far as I'm concerned, it's the only way to go. Especially if you buy the tools to make your own.
The 1.5 DOM is overkill. Even with the standard 1.25 DOM, you'll find the TRE's will bend/break before the tube bends.
Check this link for lots of info
http://www.broncofix.com/about89.html
You can tool up for about $200. That's a Reamer, and left and right hand taps. Then you'll need some tube and and the TRE's I initially saved myself a few bucks by running junkyard ends.
You can tap the .812 ID directly, but it's tight, and you have to be careful not to screw up your taps. Good quality taps help.
Your other option is to buy the weld-in threaded inserts.
Yes, you will need a reamer. One of the tie's needs to be reamed so the drag link can connect. It's also a good time to ream the knuckles from the top so you can flip your tire rod.
Even better, get yourself some drum brake knuckles, since they have a higher steering arm (center). Of course then you have to do the chevy disc conversion.
I agree with Nobody, if you are running the ford disk brake stuff on the D44 sell your knuckle out to an EB guy who just cares about the disks and go with the EB knuckle and chevy conversion. the chevy TRE conversion is a good reliable setup.
I plan to set up my full width front this way...
