good lift for low bling bling
i called around and the average lift is gonna cost like 2400-2800$ plus an aditionaly 900$ for installation...I want a good lift but dont wanna half to spend like 3500$...my one friend says just reverse the front shackles which makes his truck higher but it doesn't help his articulation much and also he's actually loosing suspension because his leaf springs are straight...help me please what should i do???
						Well, you can get lift in the rear for almost FREE. All you have to do is build new spring hangers. I'm using stock fullsize Bronco springs in the rear with home made hangers. I actually sold off my skyjacker 4" leafs because this was better.
In the front, you can do a solid axle swap, including axle for less than these lift kits go for. I'm all about keeping wheelin affordable. All you need an axle, coils springs, and some radius arm brackets.
Rough country suspension systems ad in May 2006 4 wheel and offroad, 1.5" $110.00, 4 inch with arm $430.00, 4 inch lift system for $670.00 with "FREE" stabilizer shock!!!! National tire and wheel- Skyjacker 4",6"and 8" starting at $596.00 and the systems starting at $899.00. Ford specials- 4" and 6" with arm $489.00 and $509.00 respectively.
there is a site www.TOPGUNCUSTOMZ.com there is a 4'' lift that comes with shock and everythang might want to check that site
							lay wib it dont play wib it
