It is a common characteristic of the ford ttb. It becomes more pronounced when the front coils start to sag. When you are driving the front automatically lifts up and follows the proper alignment.
I suspect your coils are are probably sagging. The rear probably has blocks to make up for sagging springs as well.
TTB is a funky suspension to begin with. If any bushings, wheel bearings, tie rod ends, ball joints etc are work, the camber can change pretty drastically.
They would probably to much. It would effect the way it drives. Aslong as it isn't eating tires I wouldn't worry. Just tell people that is how your ford offroad racing suspension is supposed to sit.
If they are toed in to far they will angle in at the top also. Since you are not eating tires I would say it is the springs. The lift kit will be a lot more work than just the springs but it is worth it. Be sure to put some kind of J-hook at the top to keep the spring from falling out of the bucket at articlation. Lift kits tend to give you longer shocks that allow this situation. After two or three drop outs on the trail you will see what I mean.
