front wheels tip in
wakefieldracing
front wheels tip in
Post by wakefieldracing »
ive got a bII and the front wheels tip in at the top what make it do that, it's not the ball joints i checked that, HELP ME ! :confused:
wakefield
Is there a lift installed?
It is a common characteristic of the ford ttb. It becomes more pronounced when the front coils start to sag. When you are driving the front automatically lifts up and follows the proper alignment.
wakefieldracing
once you start to drive the wheels are strait up and theres no lift installed on the front . but the back has 2 ince. lifter blockes
wakefield
I suspect your coils are are probably sagging. The rear probably has blocks to make up for sagging springs as well.
TTB is a funky suspension to begin with. If any bushings, wheel bearings, tie rod ends, ball joints etc are work, the camber can change pretty drastically.
wakefieldracing
would 1.5 ince spring blocks get rid of the wheel tip it look bad siting there in drive way.
wakefield
They would probably to much. It would effect the way it drives. Aslong as it isn't eating tires I wouldn't worry. Just tell people that is how your ford offroad racing suspension is supposed to sit. :redneck:
wakefieldracing wrote:would 1.5 ince spring blocks get rid of the wheel tip it look bad siting there in drive way.
I think you should try to identify the worn part and replace it. Any kind of block would just be covering up the real problem.
wakefieldracing
it don't eat tires, i didn't it want it to be a serious problem with the front end thank you
wakefield
wakefieldracing
i can't find any worn part those :confused:
wakefield
If its your front springs sagging, go to the boneyard and get a set. See if that is your problem.
wakefieldracing
if it is the front springs good becuse i wanted to put a lift kit on it. thank you
wakefield
If they are toed in to far they will angle in at the top also. Since you are not eating tires I would say it is the springs. The lift kit will be a lot more work than just the springs but it is worth it. Be sure to put some kind of J-hook at the top to keep the spring from falling out of the bucket at articlation. Lift kits tend to give you longer shocks that allow this situation. After two or three drop outs on the trail you will see what I mean.
wakefieldracing
how hard is it to put springs in the front, 2hr job
wakefield
to just put the springs in you are about right. but to put a lift on plan for a weekend. there are alot of riviots that need to be removed.
