I was looking to get some spare parts for the shake down run and was looking at the 760x axle joints......the axle I am running now has the 297x and I was wondering if anyone knew if I needed to alter the axle itself to hold make it hold the 760x?
also a D44 lockout is a D44 lock out right? if I get some off a TTB will it work on a 79 D44?
760X?
760X?
thats what I was told also. did they look the same when you pulled the axle?
I read MR. N's site again and I think the 760x is a direct replacement so I guess I will grab a couple to take with me.
ok now I have another question.....are the outers on an IFS D44 the same as the outers on a SA D44?
does anyone have a link to a full axle length chart?
I might have access to a TTB D44 for some swapped parts and was just wondering what all I can use.....
Only the bearing hub and rotor are the same. Everything else is different.DBrown wrote:ok now I have another question.....are the outers on an IFS D44 the same as the outers on a SA D44?
that is kinda what I figuered I just wanted to make sure.....MR.N's site kinda talks about the 760x but it is not realy spelled out.
do we have an axle chart on here?
I have a link on some 77 1/2 ton cheby axles also.
Here's the warn axle chart
http://www.warn.com/truck/axles/inner_axle_app.shtml
http://www.warn.com/truck/axles/outer_axle_app.shtml
