Well I just spent 2hours ripping apart the wiring harness to see what I wanted to keep and what had to go. Here is the finished product.
But I just have one question where the harness went into the cab area there are 3 sets of wires one was the computer one is the inertia switch what is the other? its a 4 prong plug square with these wires coming from it.
1 Grey/Light Blue wire
2 Green/White
2 Orange/Yellow
1 Green/Purple
The Orange/Yellow one and Green/White one both had 1 going to computer and other going to same plug as the Fuel pump on the drivers side.
Thanx in advance
							Wiring harness
				no v8? why drive?
Nope the relay is on the passenger side fender. I think if I ever do this swap a third time im gonna leave in the computer and all just so that the fuel pump relay etc is all there as it should be.
THe fuel pump relays "+" for turnigng it on is supplied via the computer relay and the ground goes to the computer so what I did this time was splice the ground right to ground and pretty much cut out everything that didnt have to do with those two relays.
The reason I did it this way was to keep the inertia switch and everything.
The connector im wondering about isn't on my '86 BII.
4x4'ers Eat More Bush!
