I am in need of the fuel line from the pressure side of the fuel pump to the fuel filter.They are no longer available,any ideas on where to get this or how to make something that will work?
I have the same fittings on my EB and you can use DOT 11 airbrake line and fittings from the local pull a part or just go hunt one down.
Also Napa sells kits for the Ford HP fuel lines but they are spendy.
HTH
