1989 Bronco II Fuel Line
DWillinFla
Post by DWillinFla »
:confused:
I am in need of the fuel line from the pressure side of the fuel pump to the fuel filter.They are no longer available,any ideas on where to get this or how to make something that will work?
David W. Will
check junk yards you will have to pull it but they will let you get it for cheap.
Post by EBSTEVE »
I have the same fittings on my EB and you can use DOT 11 airbrake line and fittings from the local pull a part or just go hunt one down.
Also Napa sells kits for the Ford HP fuel lines but they are spendy.
HTH
Trigger_2001
Post by Trigger_2001 »
84302b2
Post by 84302b2 »
there is a place here in MI called IN LINE TUBE, if they dont have it they can make it, sorry dont know there #
:wtf:
