RELAYS!?!?!?!?!
Trigger_2001
RELAYS!?!?!?!?!
Post by Trigger_2001 »
What relays what on a 88 b2??
:wtf: Need to explain yourself a little better.
Trigger_2001
i think that my fuel pump relay is bad. I don't know which one it is, and i'm not completly sure how to test it.
Trigger_2001
I put a new relay and nothin'. HELP!!!!!!!!!!
plowboy
Post by plowboy »
Could be the inertia switch. It is located on the pass. side of the tranny tunnel below the dash. Pull the carpet back and you will see it mounted on the firewall. There is a circuit breaker on the top that could be tripped. Try pressing down on the breaker to reset it. The unit can go bad. Disconect and by pass to test. If the fuel pump runs you need a new inertia switch.
