RELAYS!?!?!?!?!
Trigger_2001
Trigger_2001
Trigger_2001
Could be the inertia switch. It is located on the pass. side of the tranny tunnel below the dash. Pull the carpet back and you will see it mounted on the firewall. There is a circuit breaker on the top that could be tripped. Try pressing down on the breaker to reset it. The unit can go bad. Disconect and by pass to test. If the fuel pump runs you need a new inertia switch.
