fuel pump
SuprnaturlShana
fuel pump
hey i have an 86 B2 with the 2.9L fuel injection. when the car is off and battery/fuel cutoff switch/fuel pump relay all unplugged i still have fuel coming out of the blue line from the tank. is this a bad fuel pump or something else. i could really use the help because i don't like my wife driving the car around with a fuel leak. thanks
Re: fuel pump
maybe there is a hole in the line and its gravity feeding out. where is the leak?
SuprnaturlShana
Re: fuel pump
well i figured out it was leaking because the fuel filter mounted on the frame was leaking. and when i took all the fuel lines off the blue one coming from the tank had fuel coming out pretty quickly. and like i said, i had the battery, the fuel pump relay, and the fuel cut off switch all unplugged. to me it just seemed like there shouldn't be fuel coming out of that line unless the truck was running but i may be wrong.
Re: fuel pump
[quote="SuprnaturlShana"]well i figured out it was leaking because the fuel filter mounted on the frame was leaking.quote]
the fuel tank is higher than that filter. gravity
SuprnaturlShana
Re: fuel pump
ok well this may be a dumb question but if that's the case then why does it do it and is there anything i can do to fix it?
Re: fuel pump
find the leak and fix it.you must be able to see where its leakin
