I noticed that my car battery is about 2 inches smaller than the base/housing it sits in. This is the battery that came with the car and know that one of the previous owners liked to cut corners on replacement parts (you should see the exhaust setup).
I have a spare battery for my wive's van that is 2 inches bigger, and can crank 900 amps where mine is more about the 700 amp mark. It seems to fit perfectly in the space.
So... I was wondering if any other 2.8 engine owners specifically, or older B2 owners in general could tell me what battery they are using.....
Car battery size
Car battery size
1984 Ford Bronco II
2.8 v6 Engine
Manual Shift 5 speed
4 inch suspension lift
2.8 v6 Engine
Re: Car battery size
2.8's and 2.9's came with a group size 65 battery so if your van is a 65 that would be the battery that could go into your b2
