PLEASE HELP!?!?!?!?!?!
Re: PLEASE HELP!?!?!?!?!?!
yeah i have bypassed it with no results
86 bronco II
2.9l v6 5speed
5.5" superlift with 33 12.5s super swampers
2.9l v6 5speed
with the new harness,have you hot wired the pumps?? does it run then
i think by know if it were me, i would run a Keyed hot wire for the relay/pumps. but thats me
no it does not
86 bronco II
2.9l v6 5speed
2.9l v6 5speed
ok well how would i do that and how would i get the injectors to open also?
86 bronco II
2.9l v6 5speed
2.9l v6 5speed
you need to see if the injectors are gettin power. need a volt meter. ive never done it. find a wire in the fuze box thats hot with the key on, ahhhhh tap into the inertia switch??
is it gonna hurt the injectors to stay open all the time?
86 bronco II
2.9l v6 5speed
2.9l v6 5speed
they arent gonna stay open all the time. ya have to find out if there gettin power.
A noid light can be attached to the fuel injector harness in order to test for injector pulse
do i have to go out and buy some noid lights or can i just use something rednecked together?
86 bronco II
2.9l v6 5speed
2.9l v6 5speed
any suggestions on the easiest way to get the injector plugs off?
86 bronco II
2.9l v6 5speed
2.9l v6 5speed
is it on the sides?
86 bronco II
2.9l v6 5speed
2.9l v6 5speed
