Explorer Leaf Springs under BII's
My BII has a small amount of rear sag and I hear the Explorer springs might be the cure. Is is true they are the same eye to eye size? Should I worry about being to high in the from swapping? I'd like to bring the rear up about an inch without making it any stiffer.
87 BII
5.0 HO
NP435 4-Speed
NP205 Transfer Case
Dana44 w/ ARB
9" Ford w/ Detroit Locker
35" Pro-Comp MT's
5.0 HO
NP435 4-Speed
NP205 Transfer Case
Dana44 w/ ARB
35" Pro-Comp MT's
Re: Explorer Leaf Springs under BII's
they are a direct bolt in. you just have to filp the center bolt in the xplorer ones cause the spring is under the axle on the x and on top on the B2/Ranger. it will firm it up a bit to cause a thicker spring
x springs in this one
