why does my bronco do this...
kolton
Post by kolton »
1987 bronco II, 2.9L overdrive 4x4, manual 5 speed
so ive fixed all of the exposed wires and cleaned all of the connectors to and from the starter, starter relay, and the battery. And it keeps shorting out, i have to disconnect the brand new battery, reconnect it, check for spark on the starter relay. then it will start like a pro, but if i shut it off, most of the time, i have to start the process all over again.
very frustrating, any suggestions.
and how might you check/change the transmission fluid?
Shake and Bake
lostexan
Re: why does my bronco do this...
Post by lostexan »
I have no clue about your electrical problem
But
Heres a few good write ups for your tranny
http://www.expertvillage.com/video/1117 ... unting.htm
http://www.howtodothings.com/automotive ... fluid.html
Being a manual tranny there should be a plug on the top side of it you can stick your finger in and feel for it. If you cant feel it u need to add. I would suggest just changing it.
kolton
Post by kolton »
fixed the electric problem and thanks for the sites for the tranny, mutch appreciated.
i had to take appart the relay completley and clean all the metal, so i could get a straight solid connection
Shake and Bake
