Crawl Ratios
Posted: Thu Sep 29, 2005 9:43 am
				What crawl ratios would everyone "like" to have.  I'm running a C-5 auto.  Can I get too low?  If I use stock info on my BII I get a crawl ratio of 22.755 with 3.73 gears.  If you say that is with 27" tall tires and figure for new gears with taller tires I get 4.56's with 33" tall tires and a Crawl ratio of 27.819 and with 36" tall tires and 5.13 gears a Crawl ratio of 31.297.
Reason I ask is I'm going to put in a doubler t-case. And I have a set of Explorer axles under it now with 3.55's in them. That would put my Crawl ratio at 53.711. I have a full width 9" with 4.11's also and that would give me a Crawl ratio of 62.184.
I did some checking on some heep rubi info and with the stock 31's it has a Crawl ratio of 46.68. Corrected for 33's it's 49.756 and 36's it's 54.187.
I ran the 3.55's with 31's in another BII with a 302 and it seemed about right for the highway and did well off road. On this BII I will have 33's to wheel and maybe 36's(if I can get them from myson). I also have a set of stock wheels and tires. The BII will be driven around town. And will make a trip or two to Utah and Colorado.
So should I go with the 3.55 or 4.11's? 3.55's with stock tires will put me close to 4.11's with the 33's for in town and highway. Is a Crawl ratio of 62 with an auto tranny too low for 33's?
Thanks for looking.
Thanks for looking.
