Short ram intake
Posted: Wed Sep 14, 2005 11:01 pm
by Reinforcements
Is there anyone out there that can tell me how to get a short ram intake for my b2? Is it a custom job or is there a place you can buy them?
Posted: Thu Sep 22, 2005 7:20 pm
by Risky Bidness
ive only ever seen custom ones, ive looked for a kit that you can buy but never found one, but its really simple to make one yourself, i myslef havent made one but have seen it done
Posted: Fri Sep 23, 2005 7:51 am
are you talking about one that just comes off the motor and and has a cone filter?
ram air intake
Posted: Mon Sep 26, 2005 9:54 am
by B2JAY
I heard a while back, you could use the one from certain year dodge neons. 95 I think was the year but I'm not sure.
Posted: Wed Sep 28, 2005 10:56 am
by sailor45
easy fix go to the junk yard find the style intake you want from another car. i used a piece of climate ducting to make mine then i took that off and made a home made snorkel out of pvc pipe
Posted: Mon Oct 24, 2005 4:10 pm
by Reinforcements
so could I just remove the top portion of the air filter box and just bolt on a cone filter to the end of the existing intake hose, or is there more to it than that?
Posted: Mon Oct 24, 2005 6:43 pm
by ranger5.0
The probelm with the cone filter is that it will be more susceptable to sucking up water.If you are going to all the trouble to reroute your intake you might as well build a snorkel. BTW a replacement K&N filter works just fine.
Posted: Tue Oct 25, 2005 5:01 am
you will get more performance out of a stock replacement K&N then a cone under the hood.
Posted: Tue Oct 25, 2005 5:44 pm
by madmaxb2
snorkel it.
Posted: Fri Dec 23, 2005 5:31 pm
by Risky Bidness
get a cold air for a 95 neon, and do a 58mm throttle body swap, more power than the K&N :)
