302 in b2 what axles should i use
i have a 1984 b2 and im putting a 302 in it and i need to no wut axles should i use for it or should i keep the same ones
i dot no wut this is
I agree a dana 35 and an 8.8 would be an easy and great swap in for the axles. I know the 7.5 rear can take some what of the horse power and torque of the 302, but not for too long. It can only be made stronger with a locker. THE DANA 28 (your front end) WILL NOT TAKE IT TOO WELL! Personally I would suggest a dana 44 and a Ford 9" from an early Bronco for handling this kinda problem. Thay are closest to stock width and handle a really good amount of power normally, and if they are built up. This is one of the best and easiest options for a good drivetrain (I am of course doing this swap
). But if you wanna go hardcore there is always a dana 60 rear and a dana 44 front combo. But with that you'll have to go full width. Otherwise you'll have to do what nobody did, a complete modification of the dana 60 and/or 44. LAST BUT NOT LEAST! You'll have the option of front and rear dana 60's. Thats just too much for me, but are strong as hell. You have a lot of options. Just go look through all of them
